Quadruplecccc
- Apr 3, 2006
- 133
I have a 1976 merc. 233hp (351 windsor).Standard cooling. Was remanufactured 2yrs ago for previous owner. Said owner put larger cam in motor. Constantly ran hot and got to work on it but quickly got stumped as to why it ran so hot. Timing was off by quite a bit. Adj. made and runs great. Thought this would fix it but didn't. Pulled the heads and had them rebuilt by reputable engine builder. (He did find some problems that he fixed) New water pump in outdrive, circulating pump good, lots of flow coming through manifolds, elbows luke warm at full temp. 190* to 200* Here's the big question: Is it possible that the cam and the tight motor generate enough heat to make it run this hot? My last stock motor ran at 140* to 150*. Does beefing up a motor raise internal temps this much. I'm reluctant to run this thing on the lake under load although it seems to top out at 200* on the garden hose @ 2500rpms. All the cooling lines are where they need to be. Thought temp. sensor might be bad so I changed that , Had same results. I'm stumped ?????
