I have a 2001 Stingray with a 5.0L Mercruiser 305. I have been boating for many years and have some mechanic skills, can use multimeter, replace fuses, attach wires, change oil, construct docks etc.
This year I got it from storage and did the following.
It seems to me that there is some sensor, fuse, relay, component that is malfunctioning and essentially telling the computer to not pulse the injectors. Acts just like the kill switch is doing its job to kill it.
I have read the electrical testing and how to troubleshoot engine starting threads and my friend used the light and said everything seems normal, except for the no pulse or spark.
Any ideas for me to try? Any other information I forgot to add?
- Attached water hose and started boat to warm up engine. Started and worked perfect.
- Cut off boat, drained oil, replaced Oil filter.
- Started boat and ran for a few seconds. Worked fine.
- Took it to ramp and it would crank but not start
- Back in driveway it still wouldn’t start, lowered trailer to tilt boat forward and it started. Thought it was a fuel tank issue. Filled with 12 gallons of no ethanol fuel and also added sea foam.
- Back in water it would crank but not start.
- Back in driveway and regardless of boat angle it would crank but not start.
