Stock Props Question
youngboater
I have a 2002 75 Hp Mercury 2-Stroke. I want to know mainly the pitch and diameter of the prop??<br />Any help is welcome.<br /><br />Thanks
Tracy Coleman
Re: Stock Props Question
If it is a Mercury prop, there will be a number starting with 48-******XX P?? located between the blades. Since no propeller is shipped with the engine from Merc, some manufacturer, or dealer put a prop on it. You can take the prop off<br />and read a number like 13 X 17 with indicates the diameter (13) and the pitch (17).<br />Backfire ;)
youngboater
Thank you very much Backfire. You were right. The prop is 13 X 19. I found the 48 number went to Mercury's website and matched the number. It is a Black Max at $155 not bad. <br /> Thanks again,<br /> Youngboater
SeaDawg
That's a pretty high pitch prop for a 75 HP motor, it must be installed on a pretty light boat.<br /><br />If not, I would check my max. rpms, you may need to re-prop with a 17 or possibly a 15 pitch.
