Hi
Today I tried to fix my son in law's outboard engine.
It runs fine when the waterpump is out of the water (not too long because of overheating).
when the waterpump is in the water the engine stalls after 2 minutes. Then there is water inside the combustionarea and the sparklug is wet with water. When blown dry with the aircompressor the engine runs again for two minutes.
When we loosely unsrewed the cover over the cylinder where the coolingwater flows abling coolingwater to bleed there (thus reducing the waterpressure) the engine kept on running fine.
So how does the cooling water enter the combustionarea. I had the feeling it came in via the exhaustopening at the cilinder but that not likely as the exhaustgasses escape with some force.
All the gaskets that have to do with cooling waterregulation are fine and the thermostat workes fine too.
There is no seperate cylinder head (and gasket) that could be blown as the cylinder is made out of one piece and the engine can be split (vertically) aroud the crankshaft.
Could a leaking gasket around the propellorshaft cause cooling water too enter under the piston? and so spoil the process?
regards from Holland
Juup
Juup
