newberryfam
- Jun 21, 2009
- 35
I have a 3.7L Mercruiser with an alpha one outdrive. When the engine is running, I am getting a noise that is comming from the back side of the motor. I can see the shaft from the motor to the outdrive and it looks to be vibrating some when I get this noise and it kinda sounds like maybe there is a bearing that is worn out. Is there a bearing that I can inspect without removing the entire outdrive? Has anyone seen this before?
Thanks, Dan
Thanks, Dan
