Strange Noise
lhall8
I have just gotten my 1986 4.3 omc running, and I am concerned about a noise it is making. THis is my first boat and I do not know if there is something wrong, but it idles smoothely. Then if I accelerate (with it out of gear) it vibrates a little and makes a roaring noise. THis all happens when it is out of water. Is this normal or is there a problem.
fendersfender
Re: Strange Noise
I would remove drive and check gimbal bearing...it should move freely with no hesitation or rough spots
ss9940
Re: Strange Noise
Did you lower your outdrive while running on hose?
lhall8
Re: Strange Noise
Yes, I lowered it. Would the gimbal bearing still make noise when not in gear. Also, if I have to replace this, how hard is going to be, and is it expensive?
jlinder
Re: Strange Noise
On the OMC the shift is at the bottom of the drive where the vertical shaft meshes with the prop shaft. <br /><br />As a result, everything but the prop is turning all the time, no mater what gear is engaged. That is why you need to lower the drive anytime the engine is turning.
lhall8
Re: Strange Noise
Is there a kit that I can buy to replace the gimbal and all the seals
Richard Petersen
Re: Strange Noise
You really want to be absolutly sure what is worn out and vibrating before buying and tearing apart the drive. Pay a marina mechanic $30 or $40 to say what has gone bad. Make sure you can return new unused parts.
cosander
Re: Strange Noise
yes if the engine is spinning so is your gimbal bearing. grease it up and see if it changes.
