Re: Strange sounds coming from a 3 cyl 2 Stroke 90
Your s/n is within 5000 of mine, same year and OT prefix. I have done a lot of thinking about this and have no answer. If it is a dry bearing, which is all I can think it could be, it's odd that it happens so infrequently.
I have a few thoughts.
I am a firm believer in and user of full synthetic lubrication products. However, Amsoil is the only one of which I am aware that is full in 2 stroke marine oil; but that's their business so one would think that they have to stay the course. I use Pennzoil Super Premium synthetic blend. I pick up on bits of info here and there and possibly there is a reason besides price that Pennzoil stops at the blend rather than going full bore like in other lubes they manufacture. As stated, Merc won't tell you about theirs.
I have operated a fair amount of old farm machinery over the years, still do, and it's amazing how you can take a worn/rusted bearing, throw some lube on it and quiet it down. I can understand that a hiccup in your oiling system could deprive some bearings of proper lube, cause them to squeal at you and recover as soon as proper lube was restored. It could cause an oil burn on the bearing that could contribute to the squeal when conditions are right.
The oil mix in your engine is 80:1 at idle. At WOT it's 50. Idling for 5 minutes is running the minimum amount of oil. Yes engines need more lube at higher rpms but.......100:1 that OMC tried a few years ago got numerous negative comments on here from old salts that knew their business and the main one was corrosion while sitting up.
If you ran some premix to go along with your oiler it would give you a data point. Maybe not 50:1 but maybe 100:1. And if you used a partial paraffin based oil like the Penn I mentioned, that would take care of two unanswered questions that I have. I really doubt you will notice any difference in engine smoke as when I disconnected my oiler and went with 50:1 pre mix using Penn oil, I couldn't tell the difference at idle. And the SF should take care of keeping the engine clean.
You may have a bubble in the oil line from the tank to the pump where the oil line makes a vertical turn.
The upper bearing in your lower unit, the one just below the water pump may not be getting lubed properly. At idle it is spinning at the lowest speed and if the bearing were being deprived you would surely notice it then. I assume you are using the Quicksilver Premium LU lube in the quart bottle with the hose and pump.
That's about it for now. I'll keep thinking about it. Good Luck.
Mark
