Straping Board on Rack Question
dmoss8928
Hey Guys .... I got what most of you will think is a stupid question but I will ask anyway haha. I got 2 wakeboard / kneww racks on my Tahoe q4 and my question is how do you strap the knee board down on the rack. Like it has the long black string do you just wrap the board and tie the strap any where you can find? I did this and the board was moving around alot whilr ridding in rack? Sorry for my stupidness but can someone help me out....
David
brick75
Re: Straping Board on Rack Question
Depends on what kind of rack you have. But there should be hooks or notches cut into the bottom of the plate that the fingers are mounted on (or the fingers themselves) that the bungee strap hooks into. You just place the board in the the slot, pull the bungee over the top and down into the hooks. If you're not seeing where it hooks, maybe upload a pic for us to see?
dmoss8928
I got the Aerial brand here is a link
http://www.aerialwakeboarding.com/ProductDetails.asp?ProductCode=BT-KNEQCKRCKU-PA
brick75
Yep, same as mine. It's the two notches in the bottom of the plate that the racks are mounted on. You just pull the bungee around the boards, and hook it into both of those notches.
rallyart
The bungee goes up and over the board, or boards and stretches back to hook on the bottom of the frame that attaches to the tower. There are two slots on the bottom of that oval piece which should hold the two sides of the bungee with the pull tab behind it.
There is always some motion but the bungee should have a fair bit of tension and keep everything in place.
rallyart
birck75, you type too fast for my fat fingers.
dmoss8928
I go up and over the board but i got so much slack left so its not going to be tight and I dont see how I would hook it to the slot. Here is a couple of picsrack.jpgrack2.jpg
rallyart
brick can probably tell you more, as he has the same rack. You may be able to shorten the bungee where the permanent mount is by retying a knot that holds it in place. A quick fix is to tie figure 8 knot at the loose end to make the loop shorter and then put the shortened end into the slots with the knot behind. I'd guess they were expecting a wider board than yours is.
sickwilly
Mine is too long too.
I just tie a knot towards the end of the loop, so that it will be snug. Play with the position of the knot until your happy.
Bring a different set of toys out on a different day, just untie and retie that knot. It won't become too snug to where you cannot untie it.
I would not do the adjusting at the base of the wakeboard plate, because if you do and then get a larger kneeboard and wakeboard you will be sunk.
brick75
Wow, that bungee is crazy long. Do you know if it's the original one that came with the rack? If you bought it used, maybe someone had to replace it. Anyway, should be pretty simple to tie new knots to shorten it like the others have said.
dmoss8928
No I bought them new... I thought they were pretty long haha
