stratos 285 pro xl what prop
gunpacker
I have a 93 stratos 285 pro xl with a evinrude 150 hp intruder same year as boat . what prop should I be running it has a raker 14.5x24 on it but has some slight damage to it . I wanna replace it but want to make sure to get the right one out the gate . I want the best performance I can get but dont know if I can do any better than just replacing it with the same one . thanks in advance oh and it does have a hijacker jack plate I believe its 6"
jestor68
Re: stratos 285 pro xl what prop
Need your WOT rpm and speed with your usual load on board.
jestor68
Since you're turning good rpm, I'd see if it can be repaired. Or get a new one of the same size and use the dinged up one as a spare.
muskiemike12
Just have it repaired. I ran the same set-up for 14 years 95' 285 pro xl dc with that same prop on a faststrike 150. I ran at 5600 rpms with no jack plate and the motor mounted on the 2nd set of holes. That prop is made for that rig. Hole shot was instant and ran in the high 50's.
