I am finally ready to start. I have a 17'6 glastron. I have removed the cap, transom, and down to hull. I have purchased 1/2 inch ACX ply and 5/4 pt for the stringers,and 3/4 ply for transom. I have cut my stringers and transom and they are drying. Decking is drying flat on garage floor.
So my plan is to epoxy all the wood with 3-4 coats. I plan to use Pl poly to bed stringers and transom . I then plan to use epoxy and 1708 strips to tab the stringers and transom to hull. I will fill gaps between hull and deck with pl poly also. Can I add strength to the ply in critical areas on the underside using the 1708 and epoxy? I will then paint the deck with some paint ? I need recommendations there. Also how do you secure deck to stringers and seal the holes in the stringer? I've lost my password or i"d post new pix Sure i forgot something .http://www.shareaproject.com/pages/projectThumbs,p,478,00.html
