vintageglastron
- May 10, 2007
- 11
Hi,
As I move forward in my project (V156 Glastron) I am at the point where I'm putting in the deck supports. My confusion is with the area that holds the foam. Is that area suppose to be sealed up 100% from water. What I am concerned about is there is a drain hole in the bow under the deck that drains any water that may get in under the seats or the anchor storage area. This water just drains into that foam area down the center of the hull and into the bilge. Should I run a PVC tube from that hole to the bilge to keep the drain water from getting into that foamed area of just keep the foam out of the center of the hull and foam from the first set of outer stringer up to the wall? All the foam was removed by the previous owner and it apperars to have had foam there once before, but I can't be sure.
