Re: Stringers
First off, might want to do a search about stringer replacement. Second, pictures always help. Third, I have heard of people sticking down stringers with PL, however, you still need something that you can make a fillet at the bottom with because the fiberglass will not turn at 90 degrees. Also if you search the forum someone pointed out that the PL is not made for the marine environment. The big thing to remember is the fiberglass is what gives the strength in the stringer system.
