Stripped Spark Plug
hookups08
Alright guys,
Heres a tricky one...I replace my spark plugs and they just keep turnin and turnin, turns out there are little pieces of metal on them when I pull them out and my spark plug intake female screw piece thingy is stripped! I was thinking some lock tight??? Any Suggestions before i possibly blow myself up?
Bob_VT
Re: Stripped Spark Plug
Google helicoil which will fix the problem. There are even you tube videos about inserting a helicoil
Daviet
Two suggestions.
Heli-coils or replace cylinder head with new or used head.
bktheking
You won't blow yourself up, what motor are you talking about?
royal0014
Master Chief Petty Officer
Alright guys,
my spark plug intake female screw piece thingy is stripped! QUOTE]
:confused:^^^??
They make spark plug taps, you might be able to re-tap. Check the parts places, or the helicoil idea.
Lion hunter
^^^^^+1 on helicoil or new head. Don't use lockitite. Also the taps are junk. If there's not enough threads to hold a plug there's not enough to tap it. I tried on a lawnmower once. Ran good for about 5 minutes then blew the plug out and dang near took out my head as I was bending down to look at it.
bktheking
Get a used head, just went through this on a 64, the helicoil let go and we lost a cylinder on the lake.
As far as retapping, re tap into what, the metal is gone!
tx1961whaler
If you don't want to find a used head, take the stripped head to a machine shop and have them put in inserts. That will probably cost as much as a used head.
14ftgrumman
I'm with the HeliCoil. Make sure you use red loctite on it.
bktheking
You start by starting your own post, tagging onto another one gives us no info.
