Re: Stripped Thread - Drain Plug
I am an Engineer, and I can fix it.
However Rodbolt is right, the majority of Engineers would not be able to make the proper repairs. It?s the things that I learned prior to Engineering school and what I?ve learned on this forum that would allow me to make the repairs.
Because this is a drain plug I would be very careful using thread inserts, they might work fine but I would increase the frequency when checking the fluids.
If possible I would attempt to find the next size (up) of drain plug, using the correct size drill bit I would drill out the damage threads, followed by a fresh tap and cut new threads into the housing.
If room does not permit this operation, then I would go with the heli coil method.
Good luck
