That's what I think I will end up doing...A few hundred bucks for rebuild kits is not a big deal, but since I just bought the boat and don't know if the previous owner messed with it I could try adjustment first.In that case you never know, might be rebuild time just get it out of the way.
That is something I had not thought about, will definitely look into that. Thanks!My pump and carb comment is IF the carb is flooding OR the pump diaphragm has ruptured and is pump the excess fuel thru the clear tube and down the carb. For either one of these you would see fuel dripping down the throat of the carb. There would be no smell in the engine compartment
