Re: stuck carb jet
Just went through this problem also.<br />I assume that your jet is brass. Dang Brass has a real habbit of siezing. <br /><br />Finally had to resort to drilling it out. <br />WHAT A PAIN! Broke off an Eazy-Out in the jet. As the brass is so SOFT, the Eazy-Out, distorted the jet adding to the seizing. Went trough 6 or 8 End-Mills and Drill bits drilling out the broken Eazy-Out.<br /><br />The good news was, by the time i got the broken Eazy-Out, OUT, the remaining shell of the jet came out too.<br /><br />If you've got to drill it, see if you can find "Left Handed" drill bits. Start will small bits and work your way up. Eventually, one of the bits will grab the jet and back it out.<br /><br />If you have a Drill Press or Mill to work on, Chuck/Clamp up the carb too maintain alignment with the drill. <br /><br />Take ALL NECCESSARY TIME. <br /><br />Good Luck!
