Re: stuck carb
The question is whether it is stuck due to gummy carb deposits, corrosion or some other busted linkage problem. If its gum, try some spray carb cleaner (engine not running) and let it set with the solvent awhile. If its corrosion its going to take some time and patience and a lot of penetrating solvent to hopefully work it loose. Make sure something hasn't come undone or broken that is preventing it from rotating. (Sometimes a screw or nut can get sucked in there and jam it stuck). Worst case scenario is you have to take it off and play around with it.
