stuck drain plug?
salmonite
this is my first year changing more lower unit and of course i can't get the bottom drain plug out. i had the marina do it last year, do they use a machine or a huge drill or something? i don't want to run it to the marina just for a lower unit change because of a stuck plug. what else can do?
tashasdaddy
Re: stuck drain plug?
1/2 in wide screw driver, and a lot of pressure pushing in. don't mess it up.
tmcalavy
What TD said...if the screwdriver shaft tapers, put weight on it and a wrench on the taper just up from the plug and apply some leverage. Or an impact wrench...never can have enough tools.
wbeaton
I like a good impact driver on stubborn screws where heat can't be applied.
Hammer + screwdriver = FUN
tomh59
Put pressure on the screw driver and tap the end with a hammer. You
don't have to pound it just tap it while twisting LEFT. That should do it.
salmonite
good ol propane torch and went to home depot and got the biggest fricken screw driver and it popped right off. thanks for the advice
