Stuck Float Merc 4.3l 99 alpha1
matt2807
Here we go....
Cleared all fuel lines, replaced filter, checked pump. I have an abundace of gas right up to the nut that connects the steel pipe to the carb.
As we had this problem 2 weeks ago and it ran fine after we finally got it started I have ruled out blocked jets. Therefore my only conclusion is that the float is stuck in the up position and will not allow any fuel in to the carb.
My question is does anyone know of a quick fix to release the float without taking the whole carb apart?
I have not tried tapping the carb or blowing in with air - should I???
Don S
Re: Stuck Float Merc 4.3l 99 alpha1
Not everything has a "Quick Fix".
Ayuh,....
The Quick Fix is buying a Carb kit,+ Installing a New needle,+ seat.......
matt2807
Managed to get it unstuck with a couple of taps to the side of the carb while the pump was running - looks like that carb kit will be another end of season job to add to the list. oh joy.
Coors
Fix it now, otherwise you will break down, in a bad situation.
Ayuh,.....
If you've got Any Sense at All,....
It'll be on Next Weekends To Do List......
chiefalen
fix it now or we will be seeing posts from you in a week or 2 how you had to be towed in.
