stuck in forward gear
amcroy
replaced water pump now cant get it to shift. I have a 75 hp mariner 1991. have lower unit off prop off ect. help :confused:
denniz
Re: stuck in forward gear
Ill answer your question but first answer mine, Why is your name AMCroy? Do you own a AMC? If so what is it. Ive got a 68 AMX 390 is why I was wondering. you probably didnt have it in forward gear when you dropped your lower or if you did you spun the propshaft counterclockwise and thru your lower out of forward. Realign your shift shaft in forward gear and youll be fine.
Mod2
Moving to Outboard Engines.
