stuck in gear
jska247
I have a 40hp Tohatsu circa 91-92. It is stuck in forward gear. Even at idle(neutral) the prop moves forward. It will not go into reverse. I have since brought the boat home from the marina and checked the linkage it appears fine. The prop will not spin freely in neutral. I will say that it has been some time since I have changed/replaced gear lube. The boat was out of the water for about two years but has been working fine over the last two months. Any suggestions?
Jason
TOHATSU GURU
Re: stuck in gear
Determine why it's stuck? Is it because of a problem in the control box, a broken shift cable, a problem with the shift rods or a problem in the lower unit itself(must be taken apart to determine the cause).
