stuck in reverse help
leserz
i need a little help on this. i have a 74 merc 9.8 shifted it in to REV (engine not running) now its stuck in REV.it went past the indent. need to rebuild the carb so its off. i can see the shifter workings under carb easely.. if it makes any diference the plastic rod with the ball on the end came off put it back on . and tried to shift it and plastic rod popped off again. i'm clueless :confused:
jim dozier
Re: stuck in reverse help
Try cranking the engine over with the plugs out while you try to shift it out of gear. If you can't do that have someone move the flywheel by hand while you shift it out of gear.
