Unfortunately the water level in our lake has dropped to the point where we won't be able to move our pontoon boat until the water comes back up (could be a year or more-'drought'). The problem is the 80hp merc. (mid 80's) on the back of it. With winter on our heals I have concerns. The motor is tilted up. I can lower it only a few inches before it gets hung up in the mud. I usually run a gallon or two of antifreeze through the motor every fall just to be anal about it. The question is: Since I won't be able to run antifreeze through it this fall, will the motor self drain while in the tilted postion and be safe in freezing weather.
