Good Morning everybody
I'm working on this motor for a friend at work...apparently the impeller has never been changed. I can't seem to get the lower unit to separate...I've removed the 2 bolts from each side of the cavitation plate, and 1 from under the cavitation plate close to the trim tab (total of 5). I haven't been able to find any more bolts - including anything under the trim tab, but I certainly could have missed something... From what I've read, the shift linkage is a spline type, so the motor just needs to be shifted into forward to remove the lower unit. Can anyone offer some advice to what I've missed, or should I simply continue with my rubber mallet attack... Thanks!
-Matt
-Matt
