I have two different style drain plugs in my lower unit. One has a slotted screw driver style head and the other has an allen wrench style head. I apparently over tightened the allen wrench type screw and after a year of sitting it was very tight. Here is where I screwed up. In trying to remove the plug I stripped the alen wrench hole.
So I am trying to decide how I am going to approach getting the stripped screw out, I have come up with a few options but want to be careful. I am open to suggestions. Option 1. Use my dremmel tool to cut a screw driver slot in the head of the plug and try a screw driver. Option 2. Drill a hole into the center of the allen wrench hole and try an easy out. Option 3. I doubt this would work because the drain screw is probably aluminum but I thought of inserting the allen wrench in the hole and welding it to the screw, I thought of some kind of epoxy joint but I don't think epoxy would be strong enough. 4. My final option would be to remove the lower unit and take it to a machine shop and let them try.
So does anybody have any suggestions?
