Stuck Lower Unit Plug
jackpine
Arghhh...having a real hard time here! I was changing my gear oil on 4hp 96 Johnson that I bought used and after removing the lower plug I could not for the life of me budge the upper plug to release the vacuum. Unfortunately I have partially stripped the plug. I sprayed some penetrating oil on it to let sit overnight, hopefully that will help? Anyone have any suggestions on what to do if I can't get the plug out? Also, the upper plug seemed to be recessed into the lower unit in comparison to the lower plug, I am wondering if perhaps it was over tightened in the past.<br /><br />Any advice is appreciated.<br /><br />Thanks
rickdog67
Re: Stuck Lower Unit Plug
I had a lower unit bolt stuck on one of mine. Heated it with a propane torch a couple of times and it broke free.
OBJ
Find an impack driver jack.....one of those ones that you smack with a hammer. Should pop it lose.
reckless
propane<br /> need i say more<br /> cant belive i used to make it without the stuff
