Hi,long time reader first time poster.i have just bought a 1998 regal 5.7 with a volvo sx outdrive.i wanted to replace the belllows and gimbal bearing.i cannot get the two apart from the pivot housing and the upper outdrive.i seen on here where someone said to undo the hinge pins and push them apart that way.however i dont understand how to do this.i have it on a engine hoist right now and the drive shaft is still in it .do i just pull on it (it seems a little tight and i didnt want to hurt any thing important)also it seems that it has a build up of jb weld around the center where it should separate and has a hole in it just below the middle bolt on the starbord side.if i can get it apart ill see if thats a problem or not.it has come from florida till i got it and am in indiana.i do have a book and following it but am stuck now.thanks in advance
