Stuck prop on Evinrude 9.9
ba_50
I searched the posts on this but didn't turn up anything useful. This prop was off about a year ago, but it won't budge now. Both fresh and salt water.I forgot to grease it! Pulley pullers won't get a grip and a chisel type tool doesn't help. I can't hit the plastic on the back.
Is there a puller out there that will work? Thanks.
Willyclay
Re: Stuck prop on Evinrude 9.9
You can make your own prop puller starting with a cheap hub puller ($7.00US @ Harbor Freight), some chain and "S" hooks. I would also soak the prop shaft generously with PB Blaster or some other good penetrating fluid prior to putting a lot of strain on the prop. Good luck and let us know how you do!
Ayuh,........... Bet ya Don't do That again,.........
Like Willy says,....
You're going to have to do alittle Creative Engineering now......
If that Don't work,...... Break out the Grinder,+ Cut it Off.........
ba_50
I wrapped a chain around the back of the hub, attached bolts to chain and flywheel puller and cranked until the shaft came out 1/8" We decided to quit before something inside got bent. Thanks.
