Scary thing coming in to my lift tonight: Throttle wouldn't go to neutral. Got stuck just before it with engine still in gear, so rammed a little into lift before turning off engine at key. Now it still won't shift into neutral. Button underneath handle that you push up with middle finger is stuck in the up position, but lever still won't move back to neutral. I can move it forward and back, but not up to vertical. It gets stuck. Tried pushing button but that didn't work either. Here's what the shifter looks like. I have looked at other posts and it seems I may just have to take the back cover of the I/O in back and start spraying everything with WD-40. Any ideas? Thanks.
