dollar7499
- Jun 2, 2013
- 62
Hi there, have just been amassing parts for the swap back to vortec 5.7 (PO tried to replace freeze cracked engine with 1984 SBC engine and gave up) and waiting out the cold snaps and I am all ready to go. I built a huge hoist frame from 4x6s and CAN NOT get my drive off!
2002 Crownline 262 CR vortec 5.7 quadrajet bravo 3
I have the 6 nuts and speedo tube disconnected and have the drive in forward.. I have pulled the spark plugs so I can turn the shaft via standing on the prop. I rotate the prop one full turn and lift the drive against the wood block on top of the drive.
It opens a bit down at the bottom of the mating surface and up by the bolts on one side of the bravo 3 but not the other. The very top right nut broke off in pieces and I think the bolt is corrosion welded into the hole in the drive!
Does anyone have experience with this issue?
