Stuck upper crank seal 1963 johnson 40 hp
grumpyguy
Really stuck upper crank seal. I don't have a puller so I drilled very small hole in the seal and threaded course screws into them. All its doing is tearing the metal on the seal.
Any suggestions?
Thx
HighTrim
Put at least 2 or 3 in and pry up on all at the same time. You will need help. OR, beg/borrow/steal a seal puller! If you are near Hamilton ON I would pull it for ya.
Perhaps bring your motor to the AGM for ------Maple Leaf Chapter-----At Humber Yacht Club.-----------Should be some gray haired guys there that will help you..
