kcassells
- Oct 16, 2012
- 8,738
Tried to post this earlier but got bounced into another nether world.
Sum it up;
Kicked butt, found some odd discolorations under nearly grinded out hull fiberglass in addition to a long slurry of resin inside/on the bottom of my hull.
Any suggestions? Want to wrap up the wood, glass, floor before that stuff gets buried. I think my boat was made on Fri. after a liquid lunch. Resin had no glass in it, but it shows cracks, some I found had water still under it. On another note there are alot of glass spots with wet foam under that. Has anyone seen that before?
Pics may tell the tale. Thanks for your feed back. My other attempt to post was more detailed.
The wet foam stuff under the glass was in alot of different areas. The green slime under the glass may be mold/foam/spilt beer etc.
Just probably will grind er out but the variables/info and be appreciated.
Sum it up;
