Bullie
- Dec 20, 2014
- 300
I am working on a friend's 7.5 Mercury. He said it wouldn't start but it did for me on the 3rd pull. What concerns me most at the moment is that no water is exiting the tell tale. I pulled the LU and checked the impeller. It's new and is turning with the shaft. I put the cover back on and ran spun the shaft with a drill. Pumping water fine.
Nothing I tried gets any water through to the telltale hose. I have it unplugged at the top of #1 and no water is reaching that elbow. I connected a hose to the copper pipe. I blew air through it. Nothing.
The only thing that comes out of the elbow at the top of the engine seems to be exhaust.
Warm water will flow out the "flush" plug hole with the motor running so I do believe the water pump is moving some water.
