72 Johnson Seahorse Model# 25E72R 25hp<br />At WOT it has a miss, for want of a better word.<br />Rebuilt carb, set points .020, hard spark on both plugs, plugs gaped .030. Haven't tested compression. Starts easy. Idles fine. OK to about 1/2 throttle, then it coughs a bit evens out and starts to "miss" at anything over 3/4 throttle. What is causing this? Replaced fuel pump about 4 yrs ago. Pumping bulb makes no difference. I'm in a bind and need some expert advice. Help
