I have a 2002 VP 5.7 gi, fuel injected.
It will start only when I pump the throttle rapidly and then it will only stay running at 1500 rpm or higher. When it is running it surges +/- 500 rpm. No idle. It also pops randomly through the throttle body. The timing has been set and adjusted. (many times). The injectors were removed and refurbished. I checked the injectors when hooked up to the engine and they are only opening when I pump the throttle rapidly, tps is new, and the injectors are working correctly. It seems like the signal for the injectors to open is intermittent. There was a problem with the wiring harness having bad wires, it has been replaced. I also removed the heads and had the top end rebuilt. Here is a list of what has been replaced;
Throttle position sensor
crank position sensor
cam position sensor
distributor cap and rotor
ignition control module
coil
temp sending unit
wiring harness
fuel pump assembly
all filters
anti syphon valve
starter
heads rebuilt / all gaskets for top end
plugs
pick-up in fuel tank checked and clear
I'm stumped at this point, any help would be appreciated......
cam position sensor
coil
temp sending unit
wiring harness
fuel pump assembly
all filters
anti syphon valve
starter
plugs
