Stupid Mariner Question????
rcmickey
I have a 100HP 1991 Mariner outboard. My buddy has a 1991 Mariner 115HP outboard. We have checked out every inch of both motors the book has them as sister engines same sections same build-up. So here is the stupid question! Where does the extra 15 ponies come from, bore and stroke? :confused:
rcmickey
Re: Stupid Mariner Question????
Exhaust tuning? Ok that would make sense since it's a two stroke. I see you have a couple of Star Crafts. We do not get many big aluminum boats down here in Florida. I always get a lot of looks on my Prince Craft. Thnxx
Faztbullet
No it the carbs, the 100 has a smaller venturi/bore than the 115. The 100 uses WME-20 series carbs and the 115 uses WME-21 series. Mercury does the same thing on the newer 70-90hp 3 cylinder motors.
rcmickey
So if I buy some diffrent carbs I can find more ponies? I dont have to change anything with the ignition or timing? Thnx for the info by the way.;)
Faztbullet
"plug and play" simple.Find a blown 115 and buy carbs or better yet find a 125 and install them and beat you buddy!!!
