Stupid plug question
brad20653
1974 thunderbird formula I/O Does the plug for the drain go in from the inside or outside???
snapperbait
Re: Stupid plug question
Either way, don't matter really, long as it's in there snug... If it were me, i'd put it in on the inside, if it's possible...
quantumleap
Master Chief Petty Officer
If it were me, I'd install it from the outside, if it's possible.
crazy charlie
If it is a screw in type it does not matter.If it is any other type you will want to put it in from the outside so the water pressure will help hold it in if it was to fail.Charlie
kd6nem
If you put in from the outside the water will be trying to push in on it, keeping it there. If from the inside the water will be trying to push it from the hole into the boat. If you're nervous about plugging it from the outside keep your spare handy on the inside, but you'll never need it.
