Stupid Question about exhaust bellows
zell66
I have a AQ125 and my exhaust bellow is bad. new is $100 plus. and part wont be in, in time for this weekend. Here is my question, Can I use a type of radiator or re-enforced hose to use temporally until part come in or is that a big NO NO??
skydiveD30571
Re: Stupid Question about exhaust bellows
Its not even a required part. Just use it as is and replace when you have the time to do so. Go enjoy the weekend!
zell66
it is spraying water out of it now, so i need to replace, but I will try and fine hose to replace it with until i can buy part off ebay.
zell66
the other question is this when I tried taking that billow off the exhaust manifold it looks like it does not come off easily. Do I have to remove the exhaust manifold to get the billow off?
skydiveD30571
Oh, are you referring to the rubber exhaust tubing inside the boat, between the riser and y-pipe? I thought you were referring to the external exhaust bellows on the outdrive. You can try a temporary fix like rv silicone for just a weekend. I had one burnt and it was difficult to get anything else to seal up and not leak.
zell66
yes this is for the interior but I do not have a y pipe it iss just a single pipe 4 cylinder engine. but in order to replace it does the exhaust manifold have to come off the engine? What is the easiest way to remove that rubber bilo and replace it
lonewolf41
For a 4-cylinder, you will need to remove the riser from the manifold . That will allow you to take off/put on the bellows.
zell66
is there a diagram of this or a certain procedure in doing this?
zell66
anyone know the procedure on how to do this?
lonewolf41
Remove the clamps (20) from the bellow (21). Remove the bolts holding on the riser (22). Riser will come off and then the bellow can be taken off. You don't have to remove the actual manifold (1). Get new gaskets (4) for reassembly.
Hope that helps,
-Keith
zell66
lonewolf41 THANK YOU
zell66
After looking at my motor this is not correct diagram
zell66
here is another shot of area.
skydiveD30571
Interesting design there. I think I'd be taking the manifold off to get to the exhaust boot.
bruceb58
That's because lonewolf posted the diagram for a completely different engine, a 3.0L engine, which you don't have.
zell66
with taking the exhaust manifold off besides the bolts holding it in place and replacing the gaskets are there any other hidden surprises I should be aware of?
bruceb58
Nope...very straight forward.
zell66
So just remove bolts and replace gaskets then. Sounds easy enough.
captmello
Before pulling the manifold, try removing the rubber boot first. You may find, you can slip the rubber boot in without removing the manifold. Worth a try.
zell66
tried that. no go. not enough clearance between two ends. exhaust manifold was very simple to take off. now to get new hose today and re-install.
