I am of the understanding this is the same thing, only measured differently? The gap is the space between the points when the ignition rotor is on its apex/corner. Dwell is the degrees before hitting that apex the points begin to open? I am a little confused. I am having some issues with having my engine run at idle of 500-650. It will only run smooth at around 1000 and above and sounds great doing it.<br /><br />I have ordered a new float and rebuild kit for my carb, but was wondering if I might be missing something in the ignition system.
