Stupid question from newb 1963 35hp
BC_Jim
Hey there i have just purchased a 1963 Mercury 350 35 hp low serial # and just have 1 no 2 questions..
First question Does it have Reverse gear?
Second question best place for electric start / altenator ?
Yes there should be reverse on it.-----Are you looking to install electric start ?
BC_Jim
Thank you on the question 1 being answered , and Yes I want to install an electric start and a battery charge system
There is no room under the flywheel for a battery charging coil !!------Bracket for the starter motor is there I believe.------Is there a ring gear on the flywheel, yes or no.-----What is your $ limit to get electric start ?----Your location ?----Does the motor run like new to warrant the spending ?
fastest and lowest cost way to add electric start and charging to your existing 55 year old motor
sell what you got
buy what you need.
Chinewalker
Agreed. Adding a starter motor to that motor requires major,surgery. I've had a couple and hang figure out how to get a starter motor in there without removing the whole power head. They fixed that in later models with a two piece mounting bracket, but the early ones were a pain.
BC_Jim
Well the thing is I am trying to bring this back to life and glory Yes there is a Lark IV 40 hp on it but the lower cylinder needs a rebore. So I have a new used back up motor that works BUT I am not too sure about the workings of its system is all. I am a fairly handy person and qualified by the government to turn wrenches and have handled tougher jobs. I am asking for a reason as I want this boat to be as much of the year (1963) it was made than not . I am waiting for the manual to arrive as I have ordered one today. So Im merely asking the questions so I can start to prioritize the labour. My parents had this model when I was a kid and now wish to show my mom that I havent forgot it. when this model was brought out it set a speed record (with a 80 hp). I have had it out before the Lark gave up and I do like the way it drives and loads Now to find some schematics of it Thanks yall
BC_Jim
LOL yea thats this winters project its also heavier Im just trying to pass my summer / fall then the big work starts That and the serials for this model start at 1571114 I have # 1571211 so Its a REALLY EARLY one
The OP has picked up the mentioned 35 Mercury to replace the Evinrude until Evinrude is rebuilt !!!
1960 Starflite
Hang in there Jim. We brought this 1960 Starflite back to life. :) The 300 Merc on it does have electric start, but no charging system. Parts for the magneto are hard to find now days. BTW that's not me in photo, however he does fill the boat. :laugh:
But those magnetos were " well built " and very durable / easy to maintain.
BC_Jim
Here you can see it flashed up and the crappy patch that was done on the aft of this.
Is the 35 a long or short shaft motor.-----Post a picture from the side to show where the cavitation plate is relative to the bottom of the boat.----To me it looks short.
BC_Jim
Short shaft remote operated pull start. now to find out what the shift problem is. it wont engage reverse
1960 Starflite
Could it be that the previous owner had the lower unit off to replace the water pump/impeller? If so, the shift shaft may have been reinstalled in the wrong position. Don't ask why I suggest this. :confused:
BC_Jim
YEA I was just pondering that possibility, ... Well It doesnt appear to be moving that much water out the weep hole either, so the lower unit will be coming off. Once i have an impeller kit in hand. at least it wont take too long to repair one way or the other . Way easier than the teardown and rebuild of the 40 HP LARK IV which needs a rebore rings piston. etc... that isnt a day job. I can do that one over winter. this one should be a day to do. Thanks All .. STARFLITE thats a nice looking boat. BTW
BC_Jim
LU is off and ill have to do some more exploratory digging but looks like the unit was put together wrong a LONG time ago as the bolt that holds the trim tab took some major farting around to loosen and remove. it was rust eaten and very corroded. But now to figure out how to ensure its in what gear when I go to reassemble.. off to the FAQs and youtube.
