Stutter at Shutdown
I have a 05' 3.0L mercruiser that after a skiier goes down and i turn around to go to pick them up if I turn it off to allow them to climb the swim platform the engine has a hard time shutting down. It will sputter after i turn the key to OFF.
Carb adjustment maybe? I've never adjusted a carb before so any help is appreciated.
Thanks in advance.
Don S
Re: Stutter at Shutdown
Seriously, don't do that.
Especially with a 3.0L, they will diesel every time (aka "It will sputter after i turn the key to OFF").
When you throttle back to idle, Merc recommends you let it idle for a couple minutes to cool down and burn off excess fuel from the slow down process.
Then when the idle is slow enough, it will stop.
Thanks for the help, and teaching me the actual term.
I guess i'll just try and be a little more patient with it. It just seems really rough and i didn't want to bust a motor mount or do any damamge because of the dieseling.
Thanks again!
Chad
