submerged motor
angler0520
hey guys i have a 15 johnson tiller over the weekend it feel off and into the saltwater any ideas of what i need to do or is it even worth messing with?
wilde1j
Re: submerged motor
REMEMBER, ONCE IT'S OUT OF THE WATER (and do get it out of the water as soon as you can),
YOU'VE GOT 2 HOURS TO SAVE IT.
Following complete submersion of your outboard...
Submerged outboard engine treatment is handled three ways depending on the type of submersion
1. MOST CRITICAL - submersion in salt water
Salt Water Submersion - Due to the corrosive effect of salt water on internal engine components, complete disassembly of the outboard is necessary before any attempt is made to start the engine.
2. 2nd Most Critical - outboard submersion while running (fresh water)
Fresh Water Submersion While Running - When an outboard is submerged while running, the possibility of internal engine damage is greatly increased. If, after the outboard is recovered and cleaned (see #3), and with spark plugs removed, the engine fails to turn over freely when turning the flywheel, the possibility of internal damage (bent connecting rod or bent crankshaft) exists. If this is the case, the powerhead must be disassembled. If the engine turns over freely, continue #3.
3. Submersion in fresh water, outboard engine not running
1. Recover the outboard as quickly as possible.
2. Remove cowling.
3. Flush outside of engine with fresh water to remove mud, weeds, etc. DO NOT attempt to start the outboard if sand has entered the powerhead, as the powerhead will be severely damaged by this. Disassemble the powerhead if necessary to celan components.
4. Remove spark plugs and get as much water as possible out of the powerhead. Most water can be eliminated by placing the engine in a horizontal position (with spark plug holes down), then rotating the flywheel.
5. Pour alcohol into the carburetor throat (alcohol will absorb water). Again, rotate the flywheel.
6. Turn the engine over and pour alcohol into spark plug openings and again rotate the flywheel.
7. Turn engine over (place spark plug opening down) and pour engine oil into throat of carburetors while rotating flywheel to distribute oil throughout crankcase.
8. Again turn engine over and pour approximately one teaspoon of engine oil into each spark plug opening. Again rotate flywheel to distribute oil in cylinders.
9. Remove and clean carburetors and fuel pump assembly.
10. Reinstall spark plugs, carburetors, and fuel pump.
11. Attempt to start engine, using a fresh fuel source. If engine starts, it should be run for at least one hour to eliminate any water in the engine.
12. If engine fails to start, determine cause (fuel, electrical, or mechanical). DO NOT allow engine to remain idel for more than 2 hours, as serious internal damage will occur. If unable to start engine in this period, disassemble engine and clean all parts and apply oil as soon as possible.
1946Zephyr
Re: submerged motor
You should get it running immediately, if not sooner. Run it for at least an hour, so every drop of water is non-exhistant from inside the block.:eek:
Cofe
Re: submerged motor
wilde1j is right on.
Just a safety point to mention. Ignition OFF when putting alcohol in the carb and spark plug holes. A spark from the plug wires could heat things up fast.:eek:
pepper
Re: submerged motor
This is what i would do,take it 2 a car wash and spray it down good & clean it up , pull plugs and dry them out, drain carb.flush with gas, let all elect. parts dry good befor trying 2 start, add a small amount of oil in clinders and spin over without plugs 2 get rid of water that may be in it, replace plugs ,new gas an try it. I had a 50 that stayed under all nite but it's good 2 go now. I had 2 drill a small hole in the bottom of the starter 2 drain the water out. but anyways hope this helps.
wilde1j
Re: submerged motor
You should have submerged it immediately in freshwater until you can work on it. Salt causes rusting of internals very fast.
F_R
Re: submerged motor
If you haven't gotten it running yet, the deadline has just about expired.
Cofe
Re: submerged motor
Too much time has past. He must be doing a complete tear down and overhaul.:confused:
F_R
Re: submerged motor
If he is, what a shame. All he had to do was hose it down (or dunk it in a fresh water rinse), then start it up and run it for awhile. That would take care of the innards. Then, attend to the externals.
Man, how I hated the day after a big storm and all the submerged boats that came in, every one a panic situation.
Cofe
Re: submerged motor
Yea those storms can wreck havoc on boats. Had my first boat beached at a nearby lake, a storm came up that night and sank the rear of the boat. The Merc. 25 was half way under water the next morning. The water didn't get high enough to get in the starter, but the motor had swallowed a bunch. Took plugs out, and removed carb, made a spray bottle of mix and fogged the motor out good using the starter. Put thing back together and ran for 4 hrs. Never had any problem relating to the sinking after that. Got Lucky
