submerged starter
tystick
Is a starter that was in water be saved or is it best to just get a new one? I have used it for a while after being submerged with no issues but now is showing signs of intermittent / sluggish starting.
jeff13601
Re: submerged starter
Mine got submerged in 2000 after a lot of rain and a bad bilge pump. I cleaned all of the connections and I still am using it
crazy charlie
It depends on salt or fresh water.If it was salt,it is just a matter of time no matter what you do.Charlie
tystick
just a matter of time before what?<br />replacing or cleaning?<br />it was brackish water
tommays
if it was cleaned right away it should be fine <br /><br />if the water had a long time to start corrideing the winding and damageing other parts then you have much less chance<br /><br />tommays
elpaso
just a matter of time before what?<br />replacing or cleaning?<br />it was brackish water <br /><br />Before you replace it - brackish water<br />is salt water - its over - I hope you<br />have Sea Tow
waterone1@aol.com
The most common problem with submerged starters is stuck brushes and corroded brush wiring and or brush springs. The windings are covered in shellac and unless they have been nicked, will survive if they are washed. If your starter has been working, but is now cranking slow or intermittant, most likely one or more of the brushes are not making contact. If you have never replaced brushes in an ignition protected motor or starter, I would suggest getting a new or reman marine starter. If you are familiar with safety practices....and the skill to deal with cleaning up small corroded parts and possibly having to do some soldering....go for it.
