Re: Sugar in gas?
Yes I have seen it first hand! Sugar WILL lock up an engine. I have seen an engine saved with coke, it took about 6 weeks to fully recover it. Coke (soda)(pop) in all 8 cylidars and try to turn the crack by hand every day. When you can turn it by hand a complete revolution then use the starter to blow as much of the coke out as you can and put oil in the cylidars. Turn it over a few times, put the plugs back in, put oil in the gas and start the engine. do not warm it up, let in run for only a few seconds at a time. do this avery day for a week or so, and hope you got the sugar all out, of course the tank was pulled and cleaned also!<br /><br />by the way, gas with sugar in it will have a sweet taste, no I do not recomend tasting your gas. if you think it has sugar in it get ride of it!<br /><br />I have even sugered my own tank before. Someone was removing gas from my tank, so, I bought a 5 gal. can and some hose filled it up. hooked it to the fuel pump while I was at work, vise grip next to the tank on the fuel line to keep anything from entering the fuel line. On the way home I stoped at the store and put a 5lb bag of sugar in the tank. Next stop was to fill the tank at the regular place! next morning tank was empty
I changed the tank at work that day, and as long as I lived at that location I never lost any gas again!
