Re: Suggest a prop, 79 glastron cvx-20 w/ merc 175hp black max
Since you don`t have any examples of what RPM and performance you get with another prop it`s going to take a guess unless someone comes by with the exact same setup as you.
If I were to venture a guess, I`d say a 19 inch pitch, 4 blade, aluminium prop by solas would be a good start. Since you are using it mostly for pulling skiiers and tubes its best to start with a relatively low pitch and 4 blade. I say relatively low pitch because that 175hp could probably turn a larger prop to give you higher top speed but might suck at pulling skiiers out of the hole.
Again, I'm just guestimating on that prop but that is where I would start. Also, iboats has a sale on the Solas props right now. I also live in canada and have ordered a few from their online store and it's a better deal than most local shops even with shipping figured in.
p.s. watch your RPMS when you get out on the water. Do not allow the motor to rev higher than the maximum recommended by the manufacturer.
Cheers
