ok... I posted a while back that my revs on the engine were high(1200) when I flushed my engine. I put my boat in the water and checked it out again. They vary between 1k and 800. There is some surging going on. From searching and reading...it sounds to me like the there might be something up with the diaphram in my vro assembly.Maybe possible pin hole or something. I run my engine 50:1 and have the vro pluged up. So here's my question. Is it easier to just get at the diaphram? Or do I need to buy a kit? Which means I have to rebuild everything ( don't believe I can do that by myself because I've never done that). Or...I was thinking another option. Maybe getting a straight gas only pump to install. I figure if I'm not using the vro part..then why have to continue to worry about that section(possible leaks and stuff).<br /><br />I have the fuel module assembly that comes for the 60 degree V6 models that everything is incorporated. my manu.year for my engine is 2000. Also...if the new pump is the best way to go...can anybody recommend a place on the net where I can purchase it. <br />THX
