Summerizing '03 90 hp classic
steam_mill
I'm putting my boat in the water for the first time since I stored it in the fall. This is the first time I've done this with the new motor/boat.<br /><br />My old boat, no oil injection, I would gas it up and toss it in. (Winterize I change plugs, LU oil etc. etc.).<br /><br />My question is with oil injection, should I mix 50:1 in gas like when I got the motor to make sure it still works or just assume it works?<br /><br />Tx.<br /><br />Joe
CU2NITE
Re: Summerizing '03 90 hp classic
As long as it worked last fall and your not getting the horn, make sure your oil resevoir is full, put gas in it and head for the lake. This new motor should be very reliable. Good luck<br />Cu<br /><br />--------------------<br />RUNNING THE MOTOR WHILE LISTENING TO THE HORN WILL MAKE YOU MORN!!
