sunbird boats
dansoph
does any one know where i can get info about sunbird boats? is it possible to get parts? thanks
93evinrude
Re: sunbird boats
Don't know about Sunbird but if it's not a Sunbird specific part you should post what you need as it may be available somewhere else and you may receive some feedback.
dansoph
Re: sunbird boats
one problem i do have with this sunbird is the gas guage NEVER works correctly. it's been like that since day 1.
93evinrude
Re: sunbird boats
I suggest that you give further details as to what it is or isn't doing and then hopefully someone can help.
mattttt25
Re: sunbird boats
bought a 1997 sunbird neptune 200CC last month. love it so far. from what i could find, they were an omc brand that was sold to hydrasports in 1998. value boat, but i got a great deal and it has features that i like.
dansoph
Re: sunbird boats
do you suppose hydrasport would have info on sunbird? i,ve pulled the sending unit from the tank and it seems to work. also the guage works. i think. but the tank it self is only 4 3/4" deep.mabey that is why the guage fluctuates so much. i can never tell if i have a full tank until i fill it.
mattttt25
Re: sunbird boats
i seem to have the same problem. the fuel guage does act up a bit. i have a 65 gal tank, so i don't think its the depth of the tank. from what i've figured out, the best way for me to get an accurate reading is to run the boat a bit, then idle down to neutral and read the guage at that point. not sure if there is any way to "fix" your problem.
93evinrude
Re: sunbird boats
Dansoph.If your boat is sitting level and still,are you getting correct readings?Is your tank see-thru?
dansoph
Re: sunbird boats
my boat is a 17' bow rider with a 20 gal. tank. the guage will bounce up and down quite a lot when we are moving.some times it will read 1/2 atank for awhile then suddenly drop to1/4 or1/8th fast. when i fill it up, it will stay on full for along time. we ski and tube a lot, so the fuel is moving all the time. thanks for any help.
dansoph
Re: sunbird boats
i can,t reliy on a fuel reading when the boat is still. also the tank is under the floor so the only acces is for the sending unit.
93evinrude
Re: sunbird boats
Guages are not great in alot of marine applications.The fact that there are no or few baffles in many tanks results in more fuel movement for unsteady readings as well as the fact that boats can sit at many angles while in the water and unfortunately there is not much you can do,however,you may want to double check the actual installation and readings of the sender itself as it could need adjustment or replacing.I do not know which sender you have but here is a link to the teleflex site.Even if yours is not a teleflex,it is good reading either way.It may help.Once there you can check out the details on units including how to check them and install them properly.Check out fuel systems,fuel senders and fuel gauges.It's a great site.<br />Good luck<br /> http://www.tflx.com/tech.html
dansoph
Re: sunbird boats
thanks for your help. i,ve down loaded some info and will read upon it tonight
