Sunbird OMC Cobra 3.0 big problems!!!
jc9668201
Well here's the deal....I got this boat pretty cheap knowing it would need some work but i had no idea what i was in for.....It would start up fine but once it warmed up and got shut down it wouldn't crank so i would move the distributor and it would crank.....I did a compression test and 1 and 4 had 110lbs and 2 and 3 had about 30lbs.....so i bought new rings, valves, and head gasket....tore apart the engine and changed all that.....put it back together and now i don't have over 30lbs in ANY cylinder....they're all about 25......CAN ANYONE PLEASE HELP ME!!!???
Re: Sunbird OMC Cobra 3.0 big problems!!!
My 1st Guess would be that Either the Rings or the Valves or The Headgasket was Installed Improperly......
rodbolt
Hello<br /> my guess would be either head gasket was installed wrong. valves were given a wrong preliminary adjustment or the cam timing is off. cam timing being late will cause low compression on all cylinders. good luck but it sounds like its time to pull it all back apart and recheck everything
jc9668201
What can I do about cam timing being late?? Valve preliminary adjustment??....I thought I should just leave them loose and adjust from there...
bomar76
From this last post I bet there are a few other problems with this rebuild also.....
