sure im not the first!
68dustin
so i have a 89 sunbird & the metal sleeve where the plug goes into spins. Which causes a little water to seep in while in the water. The cause was from my brother trying to man-handle the plug. The sleeve is flared on both sides, so it wont pull out. whats the common fix for this? thanks in advance!
1ArmBandit
Re: sure im not the first!
some 3m 5200 on both sides should do the trick
i also have a garboard and it works great..
veedub
Dustin, will you let us know how it works? Im interested to see how it turns out.
68dustin
i ordered it and will have it on the water by the weekend of the 14th. So i will report back! :) its gonna be in over night, so either i wont get any sleep that night or everything will be all good!
Bob_VT
Be certain to install it and SEAL it up with 3m5200 or 3m4200. Also slather a bit of sealant inside the hole before you install it.
68dustin
just to come back and give an update!! works great with no leaks!!!
JEBar
any comments related to removing the old one and installing the replacement .... ?
Jim
68dustin
pretty much got a flat tip screw driver and hammer, crushed one side in a bit and used needle nose pliars to crush the ring enough to push it into the engine bay. When i installed it i coated all the wood inside the hole with my finger with sealant. Took me maybe 15 mins.
